1 - 1 of 1 Posts
Ok.I need help with the econo light triggered ground pinned at A30 on the p2j-003 ECU.I ran my D15 3 stage for over 150k miles with everything hooked up like stock.All the sensors and correct vacuum hoses.My econo light always worked fine for two years.My motor was getting tired so I swapped in a new D15 3 stage using the same car,ecu,and harness.
Here's what happened !!!! I accidentally reversed the wires on the econo light sending 12v keyed power to the triggered ground pinned at A30.I drove it like that for a few hours and everything runs great no CEl's but my econo light won't come on now after I hooked it up the right way.Maybe I fried the ecu just on that pin ???? I can run a jumper ground to the A30 pin and the light works fine.I just can't get the ECU to turn it on ? I hope lean burn is OK and it's just the light.Regular vtec seems fine
1 - 1 of 1 Posts
