1 - 13 of 13 Posts
2000 Ek sedan
Ok so I got some new rims 15x8 my old setup were 15x6 and never rubbed so now I got these and in one week they rubbed all the way thru on the inside on the rear tires I'm only 1 finger gap too. I havnt got a camber kit cuz my camber isn't even bad to make that big of a difference any ideas?
95 CX Hatch
Mind posting pics of how your car sits? That looks like you ran it flat and kept on driving. people be like...."My camber isn't bad and I got like no rub"
same
You need to post pics of the inner wells as well. You could be hitting something and not know it.
With that much damage to the tire you will have witness marks on what ever the tire is rubbing on
looks like you stretch tires?
ek9 hatch, ej6 coupe
They are definitely stretched, what's the offset on the wheels? Did u check the other side. If its both I had this issue with a set of Honda fit 15". They were rubbing on the upper arm which affects camber.
90 crx si/96 accord
Low tire pressure coupled with camber and stretched tire put excessive strain on the side wall...the rim itself is prolly what cut the tire
1 - 13 of 13 Posts
