So I'm mid engine swap and doing the suspension repairs while I'm at it. The passenger side all popped loose no problem. The driver side is all seized to hell and back.
The axle, tie rod end, and lower ball will not budge with anything I've thrown at them. Pickles, pullers, sledge, lubes, and shear brute force have not gotten anywhere. The axle I'm sure will have shop press out cause I'm pretty sure it fell apart in the boot without breaking the spindle free.
I need some ideas and I haven't found much else googlin about besides what I've tried to no joy.
94 Civic Cx
You can try using a jack underneath the joints itsself and a pickle fork and sledge hammer. worst comes to worst sawsall and replace
Went w sawsall... Got the motor in and wired, now its just finishing the joints and a new axle apparently. Didn't have the heat option otherwise I'd a tries that first but at least its off.
Thanks for the advice guys.
