1 - 4 of 4 Posts
I bought Venom cam gear awhile ago for D16. I cannot find the receipt or part number to see which cam gear i have. Since I'm on process of getting the timing right not knowing which gear i have makes things more confusing.
Venom Cam Gears - Black C21-130BK 96-UP Y8
Venom Cam Gears - Black C21-129BK 92-95 Z6
38 tooth.
I'm 80% sure its for 96-up but that's not enough.
Thanks.
well one way would be pull the bolt out and see if the key way matches with the 0 degree mark if so it is below 96 if at an angel it is 96 and up refer top this thread if teh cam gear you have doesn't match you head
1 - 4 of 4 Posts
