ok, ive got a ccfab log manifold and a master power .50 turbo. All i need is another 1/4-1/2in of clearance to get the turbo to bolt up to the manifold. The cold side of the turbo is touching the outer left edge of the shroud on the ac fan, and the outer most bolt on the 5 bolt side of the turbo is barely hitting the center of the fan gaurd. Any recommendations on getting this to fit? Can that until be moved back at all, is there a slimmer fan i can install? will get pics if REALLY neccessary... hard to hold the turbo in place and get a pic by myself.
darren
I can't read...
either cut the shroud if at all possible hard to tell with out pics or get a slim fan which would be way more cleaner.
very true. i ended up trimming the shroud with mine. a slim fan would be your best bet if your trying to keep it clean though.
