1 - 3 of 3 Posts
Y
so i got a d15 and i need some help or advice with this problem that has arised with my motor. So the metal like was leaking oil and i replaced it. before that the clutch was to the floor because their was no pressure. now i replaced that and the slave cylinder is leaking oil. do i also need to replace that or did i just toally screw up. let me know whats up guys..
if the slave is leaking oil,, then it most-likely needs replaced.
1 - 3 of 3 Posts
