1 - 3 of 3 Posts
civic
i have a 92 honda civic dx sedan with d15b7 engine, im planning on gettine d16 engine and ecu, can i use my stock harness and the stock tranny its an automatic but i have plans later on conversion to the 5 speed.
what kinda of performance tranny wise will i have?
with this swap will i also beable to use my old ecu or do i need to use the one im getting?
I can't read...
no you can not use the tranny. it's for a d-series. if your going b-series you need a b-series tranny plain and simple.
About the wiring harness unless the b16 your throwing in there is obd1 then you will need a conversion harness.
1 - 3 of 3 Posts
