T
ok heres the problem my cars idle started to jump from just under 1g up to 2 and it wont stop and then it started to overheat and lose all of its antifreeze as soon as i put it in it comes out right by where the waterpump is i was told it was the waterpump so i replaced that and it still overheats and the idle is still all crazy i wasnt to worried about it causei am plainin a motorswap d16vtec well i cant afford to just wait and build my motor and not have anything to drive so anyhelp will help me out alot
yellow bar for me
viper blue 92 eg
wow no periods. lol it sounds like the problem i had with my b16... i put a new o-ring and some silicone on the end of that water pipe on the back of the engine. i replaced the one by the water pump. but there is one on the side by the thermostat. make sure to put plenty of silicone if its rough in there cause i had to do it 3 times before it worked
T
ok ill try that when i get back in three weeks
