I have an 88 crx si, cp pistons 9.1 compression, eagle h beam rods, arp head studs, cometic head gasket, t3/t4 turbo,eaqual length manifold, spearco fmic, greddy type s bov, new motor mounts w/ inserts, wahlbro 255 fuel pump, aem fuel rail, plus more i forgot. when i throw about 3-4 lbs of boost @ it it throws a code hesitates and when i let off it wont idle and hard to keep running @ low rpm's. I had someone tell me its the map sencor, that stock hondas cant read that high. im not familiar with obd0 or older hondas. id appreceate any help i can get. I did some searching but im not that good with a comp so please dont flame me
my bad im using turbo link with extra injectors, which i think is a lil lean. would leaning out the motor throw a code on the obd0 cars?
