1 - 12 of 12 Posts
When I got the car the passenger window
Wasn't working already. I already replaced regulator and motor and nothing . When I press both switches at both sides the dome light doest blink . In guessing there's a bad wife somewhere . Is there a way I can connect the power straigt to the battery ? Thanks
why would the dome light blink anyway? theres always a bad wife, but you gotta stick it out for the kids.
1995 Honda Civic Ex
Why did you replace the regulator? (noise,binding)
When you say "doest" was that supposed to be does or doesn't?
Yes, there is probably a bad wife somewhere. She's probably cheating on her husband right now but I don't think that's the problem with your window.
Did you check the switch?
Did you check the fuse?
Did you check for power to the switch?
\/Your Mom Was Here\/
Vibe GT
Why are you throwing parts at it. Chase down the problem with a test light/volt meter and see where the problem is.
Must spread Rep before Alan can get more blah blah blah bullshit...
My guess is the driver side lock switch is on
had that happen on someone elses car. was a face palm moment but funny as fuck
Lmao . I meant to say bad wire. And yes I checked the switch . Now I'm going to check the fuse and check for power thanks
check the driver side door wiring too where it comes out of the body and into the door. a friend of mine had the wires break/pull out of the plug and cause us to replace the plug.
1 - 12 of 12 Posts
