1 - 4 of 4 Posts
well i took out the intake manifold to see if my injectors were working then i tried to start the car to see if gas comes out... no gas came out so i said it must be my wiring... we also did a power reading on each of the injector plugs and it has power to every single one so help ASAP..... thanks
crx and ford ranger
after you check all the relay and wireing id check those injecotors tehm selves as in replace them for sure
1 - 4 of 4 Posts
