1 - 1 of 1 Posts
hows thing woundering if you all can help me
looking at building a d15 sohc vtec turbo and was woundering wat parts wound you recommend
want to do it properly
most importly advice on parts too forge the block
im new member to this thanks for you time
heres the spec on the car but standard bottom end
Bottom end destroyed. Head in good nick with valve stem oil seals done less than 1000km ago. New honda timing belt, tensioner, water pump less than 1000km ago. ARP head studs (re usable!)
A/C removed
Greddy TD04 turbo kit including Greddy cast manifold, hardpipes, fmic, type s B.O.V., TRUST air filter and TD04 turbo with internal waste gate.
Full custom turbo back exhaust from E.C.C. (2.5" stainless steel, flawless)
Evo 3 490cc injectors with 10ohm resistors wired in (work perfectly)
CROME PRO ecu (very good ecu has been used on hondas all over the world including Al himself's B20, Dara's H22 eg and inspector01's 400whp integra)
Custom Oil feed and return lines, with oil pan modified to suit.
Drivetrain
VERY rare Honda LSD gearbox.
Exedy Racing Clutch with less than 1000km
1 - 1 of 1 Posts
