so im getting a really good deal on a zc cam and i was wondering if it would work just perfectly fine with my d16z6, tried to research it but all i get is people arguing that it would and wouldnt fit and that its non vtec or is. as far as i know it is. and that have heard zc cam is a little more aggressive. true? help so that i can go pick it up tonight!
Yes it will fit because. Zc sohc vtec is like a z6 ..... but I'm. Like 75% its not more agressive and its the same ... the motors have the same hp rating so yeah ...
88 Civic Hatch
just keep the cam you have in now..if you really want a cam, just go with a 260-272 delta regrind. with that said you wont see real results unless you tune your car, which is still fairly low if the rest of the motor is using stock internals
