Hey all,
First I have a 88 CRX HF with DOHC ZC swap, the stock HF trans, axles and hubs. I was wondering if I get the ZC trans and do a 90-93 integra hub and brake upgrade on the front, what axles should I use? do I need a intermediate shaft? or would it be just as easy to get a SI or EX trans and go from there? but still i have no idea what axles will work with that combo? Keep in mind that I will be doing a integra brake and hub conversion. I dunno if this is even in the right section but its a trans question. any info you all can spare will be a great help, thank you!
