1 - 4 of 4 Posts
engine was rebuilt for spinning rod bearin now we have a a cel for injectors but before the rebuild, the cel wasnt on... also car misfires.. has y8 crank and pistons in the Z6 block and z6 head .04 cometic HG. are the spark plugs different from the Y8? we calculated around 9.8:1... from stock 9.2:1
also the car has a pulsing idle on the initial first 15 min start up it idled fine for the 15 min, we changed the oil let the motor cool down and started up and it would pulse...
i save your ass when you wreck
is ur iacv clean? that usually causes the pulsating idle on a lot of civics.
could be the idle needs adjusting
1 - 4 of 4 Posts
