1 - 10 of 10 Posts
hey guys.. i just did a minime swap in my friends 93 si hatch...
its a y7 block with a z6 head.. everythings hooked up and it wont start.
ive got fuel & spark , firing order is correct, running a p28 ecu, timing is perfect, has compression, just wont start...
any ideas? just cranks and cranks....
help!
thanks in advance
whatever runs....
you've got fuel, you've got spark, your timing order is correct, but it won't start. Idk, it sounds like timing is off to me, or else it should start. Does it even attempt to stumble?
its imposible for you to have alll that and then not start....you are probably misfireing like a bizznich...check your timing...and then check for spark...then check for fuel....
everything is good now.. the harness i bought was hacked by where you would wire in a resistor box so i cut that plug off an old harness and spliced the wires back together to complete the circuit so it fires right up..
had the same problem with my y7/y8 mini me just kept turning over i would seriously check your valve lash mine was way off due to stupidity.Just readjusted them and it fired up like a champ.
1 - 10 of 10 Posts
