1 - 6 of 6 Posts
98 Civic EX
I have a D15B7 block assembly and a D16Z6 head, I need to know which head bolts i should use and which timing
belt to use?? i'll be putting the head on tomorrow and need this info ASAP! thanks in advance to anyone who can help me.
98 Civic EX
reuse which headbolts?? Z6 or B7??
If u r goin to use the z6 timing belt u should put a z6 water pump.So everything would match with the timing belt.
J
i might be an idiot, but im thinkin the waterpumps are the same, dont worry about hte pump, the z6 belt is the ONLY belt to use, and reuse your b7 bolts those are the ones u want... oh yea dont forget to pull the oil jet!~!!!!!
1 - 6 of 6 Posts
