1 - 3 of 3 Posts
B
ok i have a 91 si a6 block with a z6 head and everything is stock what kind of turbo should i run and what psi and would the compression play a role in it
K
alot of people here will always ask what is your horsepower goal. we can't really give you any advice since we don't even know you horsepower goals. but then I would say a t3 should fit your needs and boost 8lbs of boost. don't forget tuning also.
1 - 3 of 3 Posts
