okay, im having a big problem identifying the differences between the tps and map sensors. i did allot of research but came up with the following info.
this is actually from a PGM-FI troubleshooting flowchart.
im confused. neither of my plugs ( map or tps ) had those wired going to them.
so heres what i have to work with.
That's odd man, mine has the colors like mentioned above. The map has a white, green/white, and the yellow red.Let me see if I can come up with anything else for you
wait...?
you are worried about wire color with cut connectors..???
why should it matter at that point...?
its just a connector...wire color does not matter
wait...?
i cant see the first pic...it doesn't load...
i'm sure i could help if i knew something i'm missing.
does the motorola use the same connector style as oem...?
i'll do my best until someone chimes in with the answer...lol
maybe i can answer it first...ha
wait...?
sorry about the pic, heres a massive version of it. and my harness isnt quite hacked, but i did do a motor swap which is why i need to know which is which.
yeah really what hell are you asking. wire color doesn't matter as long as the wire is going to the right place.
are you asking which sensor is MAP and which is TPS? MAP is on top of the TB and TPS is on the side.
actually that help me allot.
that shows that my map is wired correctly. funny thing is that youre wires are just like mine and not like ducks. thank you
nope, the connector was hacked before and wired right into the 2.5 bar map sensor. the oem map sensor is still mounted to plug the hole just like it was before.
well im done with this thread folks. its served its purpose. unfortunately the car still wont start. so im ending this thread and going to cut my wrists.:done:
Ok so I’m trying to tension the power steering pump where it needs to be and realized the car didn’t have part of the items needed to do so.
My question is what other piece do I need to complete this so it will stop squealing randomly?
Portion missing is piece that the wingnut bolt threads into...
So I'm going to start that I need a new starter and dizzy for sure but cause I hook up a z6 harness to a y7 block ? And I'm thinking about just getting a z6 block and putting it in
Need a second opinion here:
I have an 89 CRX Hf that had working AC, not amazing, but it worked. I assume it was R12 as there were no converter nipples going on.
A while back someone hit let head on, broke the radiator and mangled the condenser, but didn't rupture it.
I decided since I was...
