k i have about $1000-1500 for my budget build. mainly wanna do my bottom end so i can get better #'s. i currently have a Td04H but i am upgrading to a T3 with .42 int .48 exht. and external wastegate. just looking for so recomendations on parts and prices for them. i have a Y8 block sitting there ready to build...
Eagles/ Vitaras/ACLs/generic gasket kit/bore & hone block/balance & polish crank/ DIY "higher" flow oil pump/OEM Y8 HG/ and that'll get you started...
^The above for around $800 sounds like plan! Hey wait, that's my build...
Then piece together the turbo kit and get some management and you will have a solid set-up.
Sounds like my build to should be done by May. You should post some info about the DIY "higher" flow oil pump. Good luck on spending your money.
I was talking about the Endyne (sp) mods that you can do help the oil flow better. Shim and port the oil passage way... Someone care to post a link to it for him?
the MAD scientist
I'd get a bigger turbo with a built motor.
