1 - 6 of 6 Posts
I've got two sohc vtec heads, one is a z6 and the other is a Y8. The cam out of the Z6 does not appear to be a stock cam (I could be wrong, I don't know much about sohc heads.)
Here's the cam that came out of my Z6 head:
Pic of the only identifying mark I found on the cam (I've googled that ID with no luck.):
Here's the cam out of my Y8 head for reference, this one appears to look more like a stock cam:
I should also mention that the VTEC lobe on the mystery z6 cam appears to be slightly larger; any help in identifying this cam would be great!
top one is stock z6 cause it has the 4 lines in the core with the pressed on lobes, the second one is a stock y8 cause it has a solid core with the lobes ground on the core.
also there are two types of z6 cams one has nerrow lobes and one has wide lobes both are the same cam, but there is speculation af the wide lobe cam is a little more lift but again its speculation
1 - 6 of 6 Posts
