I need to know the size of the banjo bolt, or know if they are the same as used in fuel filter... I tried the banjo nut that goes to the fuel filter, but I'm not sure if it will be the same
this is the nut what i need
if you're desperate, you can always take a regular bolt that fits and drill it out to make it a banjo bolt - I've done it before without issue.
Love the Civic
Do you need the bolt, not circled, or the fitting, circled?
The bolt is easy, they have them at hardware stores. That fitting is pressed onto the hose, take it off and go to a pneumatic hose place that repairs tractor hoses and such and have them fit a new one.
