1 - 14 of 14 Posts
So i went through this car wash where you get to sit in it while it cleans. My car was on and it was in neutral. Got through the whole wash and then I went to vaccum the inside. Finished vaccuming, and then tried to start my car and it just made this clicking noise. Checked the fuses,distributor,spark plug wires, and everything no start. To make a long story short i had to push start it to get home. I have a hood tilt if that helps and an intake. Anything that you guys think might have caused it to not fire up after washing the car would be greatly appreicated!
no start just a click click noise. It sounds like its coming from the starter. Oh and also my battery is dead now.. kinda weird
Formally known as SPONSOREDCRX
Check your terminals. They may have been loose and drained the battery.
peterbilt
hmm maybe hydro locked try takin out the plugs and puting em back in? maybe a ground wire got loose
peterbilt
pull the distributer cap off and check to see if any water got inside.
if it was that wouldn't it at least crank? just curious
So far no water in distributor, ill check the terminals on the battery...stupid car wash haha
It could be that little plug that connects to the starter that almost looks like a speaker terminal i know im not the only one thats experienced that thing coming off. other then that mabe a bad battery terminal or ground.
Yea it sounds like either loose terminals or that the battery just went.
yes checked fuses but im thinking maybe the fuses got wet. and checked the little speaker wire connector and its in. Maybe the battery terminals went bad. And i took my battery to autozone so they can test it and it came out good..still stumped
1 - 14 of 14 Posts
