Need some help, got my turbo kit done last night. Started up just fine, ran just fine, no check engine lights, ripped on it for a hour or so. Then just cruising down the interstate it loads up, throws a check engine light on and wants to die. Only way to keep it running is in boost or ripping on it. It runs very rich once this happens. And now every time i start my car it runs great for about 30 seconds, throws the light and loads up. I read on H-T that if your ECT temp values are incorrect that it will run rich when warm, but i didn't touch that at all so im not sure if that would be the problem?
Better to have too much ECU/Chip information than not enough, wanna get this taken care of so if there is some info you need...let me know.
Mini Me
t25/log
DSM 450s/Resistor Box
Stock FPR
Stock fuel pump
Crome p28
ill add the crome bin file if you want/need it...
are you logging any way? show us the logs hi and low cam
What code is it?
Warning your full throttle shift is now you new rev limiter.
Sorry your new rev limit. I cant edit my post??
