1 - 6 of 6 Posts
EG hatchback
Hi i got a current build engine rods are out and I'm wondering if i can use a dremel tool to engrave the Rod #ids on the rods.
like put the number on the rod cap and on the rod close to the cap so i don't get it mixed up for reference.
Like 1,2,3,4 etc.
is it ok?
i don't got a special number stamping tool and don't wanna buy one and all i have is a dremel to use...
why would you want to potentially put the rods out of balance, or at least further out of balance?
use a permanent marker or an oil marker
\/Your Mom Was Here\/
Vibe GT
Harbor Freight and $5 can have a stamp set...
But if you do use a dremel to mark them then make sure you do it inside the journal so you don't see it after install ;)
JK... Don't dremel the journal lol...
1 - 6 of 6 Posts
