1 - 4 of 4 Posts
civic & thouwi Kawi
Will OBD-2 LS B18 (AUTOMATIC) throttle body work properly on my manual d16y8?
I have searched but cannot find the answer. Can I just remove and block off the FITV? Please help!! :surrender:
This would mate to an Edelbrock Performer X IM.
Thanks!
civic & thouwi Kawi
Discussion Starter · #2 ·
Will this work? B18 AUTO TB on D16Y8 manual car.
Will B18 Auto Throttle Body run/Idle correctly on my 97 civic EX?
I know they bolt up. I read to get the TB Gasket that matches the TB. I have this throttle body and I Need something to install on my Edelbrock Performer X Intake Manifold. I read to block off the FITV that is on bottom of TB.
Before I spend money on a Gasket, Can anyone confirm if this will run properly?
Love the Civic
I don't believe you didn't find answers when searching, took me two seconds to find the answer, but I kind of already knew. Unless your searching skills are dull...........yes it will work.
BUT, you will need to port match the 60mm TB to the 56mm IM, either gasket (auto, or manual) will suffice.
You doing cam work and/or a tune? I hope so other wise you are not benefiting at all from the TB upgrade. Just curious as to what you are up to over there.....
1 - 4 of 4 Posts
