1 - 4 of 4 Posts
i having weird problems with my car lately. 1994 civic lx 4 dr with d16y8 swap.
the issue is when the car is running it will randomly start missing on cylinder #1 then it will run fine again. sometimes it will happen as soon as i start the car and sometimes i will drive it 50 miles and not have the problem.
i have replaced many things and still can't find the problem.
replaced:
fuel pump, plugs, distributor, wires, engine wiring harness, ecu.
can anyone help this is my only car!
98 Civic Ex
Injector? Try switching them around and see what happens...
Maybe the misfire will switch to a different cylinder and then you have your answer?
Timing?
i don't think it's the timing because it dosn't do it all the time but i will try switching the injectors to see what happens
1 - 4 of 4 Posts
