1 - 20 of 45 Posts
hi guys!
im a spanish honda addict but in spain the honda world its too poor in upgrade parts and info for build a great engine.
i have a EK hatch with D15Z6 vtec-e engine with this mods: apexi vafc, cai, 4-2-1 header, N1 muffler, and 10.3 sparkplug wires.
i know that this engine its rare on USA but i hope that you give me the good info for upgrade my D engine to be faster.
what parts and brands i need to change for increase the power? what is the best, oem parts configuration or an aftermarket?
thanks 4 all!!
EDIT: i dont want to put nitrous on my engine :p
sub-sponsor
93 civic
if your worried about it blowing on spray if you use a wet kit and run a step colder plug you'll be fine
1995 Honda CIvic LX
Yep. I've seen crazy amounts of nitrous ran on stock motors as long as the setup is right. You can get by with a basic small shot and be fine.
1995 Honda CIvic LX
oks, this is good mod ;)
As long as you don't do it fast and the furious style and try to run a 500hp shot you'll be ok. I'd say no more than a 75hp shot, but nep-tuning could probably tell you better than I could.
sub-sponsor
93 civic
i'd do no more than a 100wet shot 3degree retard cam, colder plugs, for you i'd rn no more than a 75
the nitrous is a good option but i dont want only put a nitro, i want info of setups with diferent blocks/heads/pistons/rods/cams and another mods for increase the 115 stock hp's of my d15z6.
like i said, in Spain the people only do a swap D to B series and the info for increase the hp's of D engines are really poor.
my english its also really poor :p
DROP IT LIKE IT'S HOT
2003 Civic Si
No te preocupes de tu english. Well what engine would yours be equivalent to here in the USA?
gracias CxHatch ;)
my engine its a D15z6, 1.5 16v 115hp VTEC-E of an 96-00 EK.
in USA i think that my car is the EX.
2003 Civic Si
Dejame ver...?????... Why not upgrade your intake manifold, a stage 2 or 3 cam con el valvetraint adecuado. Maybe some high compression pistons.
i shown that some people in thsi forum puts the d16y8 intake manifold in his engines but i dont know the reasons about this.
this its do it only in non-vtec engines? or the d16y8 IM its best than another D intake manifolds?
i think in install a engine kit but i dont know what setup and brands are the best for obtain the most number of hp's.
The Great Weldini
91 civic
Discussion Starter #20
if u want some n/a power swap to a 1.6l
his motor is more similar to the jdm d15b with 3 stage vtak...
i dont want only to do a swap and anymore, i want to build a great D engine with a powerfull compression and with the most number of hp's.
but for this i need a great engine setup and i dont know anything about this perfect setup :S
1 - 20 of 45 Posts
