1 - 1 of 1 Posts
Civic EG4
Hi
Thought I'd better sign up after reading a few threads over the last few weeks.
I own an ukdm spec eg4 vei which has the eco vtec d15z1 :poke:
Will be going turbo once I get the rest of the parts sorted out, but will be doing the Z6 top end conversion which I know will give low compression due to the dished pistons, have most of the parts ready like manifold turbo downpipe, injectors, intercooler etc and S300.
Just wanted to double check which head bolts and timing belt to use with this setup? I've read on a few threads the head heights are the same (z1/z6) so using a z1 timing belt and tensioner should be ok? Haven't seen anything mentioned about the headbolts though.
Anyway thanks in advance :eek:
1 - 1 of 1 Posts
