1 - 20 of 31 Posts
Hey guys!
This is my first ever post on this forum. So first of all, hello to you all! And thank you for all the good threads!
I just swappe this d16z6 into my ej9/ek 1.4iS european version. And it had this weird distributor on it.
136493
It looks like a regular obd1 dizzy. But it only has 7 wires coming out of it? My guess is the previous owner cut the plug of it, and converted it somehow? But my issue is, the wire colors don’t really match any other dizzy/wiring harness diagram I can find online?
I’m running a obd2a harness with this plug onbut it needs 9 wires? I can find a diagram of the harness. But none what so ever of this specific dizzy??
136494
So if you know something, PLEASE help! I’m really stranded here ☹
Best regards Silas.
are you sure its not a stock z6 distributor? or d15b7?
Discussion Starter · #4 ·
you should open it up it probably has a missing wire borrowed/broken off inside.
what are the colors can't see the stripes ..
I have now taken the dizzy apart. It doesn’t look like it’s been tampered with. Not what I can tell at least. But then again, I’m not much of a Honda mechanic 😅
But it’s clear that it’s been opened.
Here’s some pictures. It looks like the wire colors are a bit faded??
136504
136502
Auto part Technology Vehicle Automotive engine part Car
Hope this pictures helps a bit.
Discussion Starter · #5 ·
I’m not really sure of anything.. Honestly I’m not much of a Honda guy. This is my first 🙂
But I can’t really match the wire colors to any diagram I can find online??
any markings on the dist?
a google search of those numbers say its a d16z6/z1 dist
Discussion Starter · #9 ·
Yes. But the colors mine have, is not the same as the factory dist...
Also, the factory one have 9 wires. Mine only has 7. Is it because different stuff needs the same signal/wire?
the obd1 also has 2 plugs. (1) 7 wire and (1) 2 wire.
its to show you they came with 2 plugs in obd1.
Reactions: Silas
Discussion Starter · #20 ·
was there 3 sensors inside ?not
so this can;t be used ?
external crank sensor/?
There were only two sensors.. can I wire the sensor from the transmission to the distributorplug??
It’s the CYL sensor I’m missing.
1 - 20 of 31 Posts
