1 - 20 of 44 Posts
i have an aem sri on my z6 and want 2 paint it (that shiny chrome look is just too blingtastic) and want to try and keep it from heatsoaking.....would i be better off using dupli-color engine enamel with ceramic?(used on vc, still have can) or krylon bbq&stove paint (used on headlights, still have can)....i know they both withstand heat but which one would help keep heat out of my intake?...t.i.a
97 GSX-R 750
If you wanna do it the right way use the BBQ paint, then heatwrap it. Heatwrap holds moisture and that means metal damage. Paint, wrap, forget!
97 GSX-R 750
Discussion Starter · #15 ·
im gonna use the bbq paint b/c its flat black and the engine enamel is red....just got tired of the shiny chrome intake and figured one of the 2 MIGHT help a LITTLE
Well i work at autozone and they had some cans of Engine Enamel Paint the 1500 degrees F in aluminum color for $2 a can so I took all the ones they had and I did my intake and to tell you the truth that stuff really keeps the pipe alot cooler not that its painted than before when it was just the natural polish. That stuff really works i even did some brackets on the engine bay and my front brake calipers just for authetic reasons.
a car
the intake manifold or the tubing? if manifold i def consider this as an option..building a n/a d series build and need any help u can edge i can think of
heat wrap FTW!
Im using DEI's heatwrap paint its silicon based so its an even better inuslator then regular paint, it also is meant to paint the wrap with it so it wont absorb moisture :)
1 - 20 of 44 Posts
