Im gonna be spraying about 75-80 shot on my engine.
Im currently using NGK R5671A-7 plugs, 7 heat range, but am switching to bk7re's. Will 1 range colder be ok or do yall recommend 2 steps?
I may be stepping up to 100hp if things go well and the bottom end holds lol
Stay with what you have, goto -8's for 100 shot and pull enough timing.
The shorter reach of the R5671's means less likely the ground strap will melt.
Ight. Ty. Im pulling 3 degrees for 80 ish. Im running conservative timing already, planned the engine for spray. 14 degrees base with a y8 head on a z6.
better pull more depending on the tune in the ECU.
I'd pull at least 4 degrees from base to start.
Are you wet or dry?
Dry. Fuel is being added by the s300, and timing is being handled by it also. The spray will be dyno tuned.
Edit: should I pull the timimng from the dizzy? With the the s300 nitrous control, I can just enter the amount i want out. I imagine it pulls it out overall
