1 - 2 of 2 Posts
Ok this is a problem Ive been having for a long time and its just getting annoying now..... one of my headlight lamps is uneven, or what I mean is its pointing up a lot higher tha the other, so it looks like one headlight is brighter than the other, but in reality they are just uneven, how do I adjust the headlamps?!?! 96 civic...... thanks
if you look at the back of the housing, there should be a few screws that seem to be screwed straight into the headlight housing. Tightening them or loosening them will adjust the beem. Not sure how many you have, but if it needs to go down start with loosening the top screw (and or tightening the bottom one, if there is one). Park about 30 feet from a wall, and make sure they are at the same level and you are set.
1 - 2 of 2 Posts
