1 - 6 of 6 Posts
Trade Me Your Car Please ...I Am The Master Of Fli
when i turn my headlights on every light goes on except my driver side turn signal. if i turn on the blinker it works and blinks normal but with the headlights on the light stays of unless the blinker is ingaged.
does anyone no my problem?
is a two way bulb, and one of the filaments is burned
needs to be replaced
is either that, or the little contact on the bulb socket is bent down and is not reacing the contact on the bottom of the bulb
well if i get ssome cash up ill let you know if the bulb does the trick
just take the one of the other side and see that it does, if dont work then just check the little contacts before u go out and buy new bulbs ;)
1 - 6 of 6 Posts
