Could you help me ? I have a Civic 5th generation, I need the electrical wiring diagram for mount the new headlamps, high /low beam separated, (H3 and H1 bulbs). see the pic. thanks
Lurking... ಠ_ಠ In Your Thread
ES1 Civic
see my sig, all your answers are there.
indeed. great info there! and also, talk to member "torturedsol" who also has projector headlights that he loves sooooooooooooooooo much! he will tell you all about his harness that he has.
The Great Weldini
91 civic
i need the manufacturer manual! if it is possible in pdf.. thanks
thats what it is numbnuts. it's the service manaul in pdf.
You only need that if you're running higher wattage bulbs. And if you want the lows to stay on with the highs, change the one wire in the headlight switch. It's all in the manual.
