1 - 7 of 7 Posts
Does anybody know who sells the gasket that goes between the header from the top to end part? Also would an OEm header gasket fit nobody sells just the gasket?
PLEASE HELP.
Header Type: DC 4-2-1
Tman the Zman said:
Are you asking about a gasket that goes between the 2 parts of a 2-piece header?
You can use a stock exhaust manifold gasket with a header, but you can also get aftermarket ones.
Yes. The gasket between the two-peices of header.
Tman the Zman said:
there's just 2 O-rings that go between them, but if you're missing those, then you should just call up DC
Yeah thats what I'm missing. I brought the header used. So before I put it on I just make sure there are no header leak.
1 - 7 of 7 Posts
