1 - 10 of 10 Posts
want to swap a fuel injection head onto my 1985 1.5 cvcc honda civic wagon an d use motorcycle carburetors thanks
08 H-D Ultra Classic
Okay and?
98 Civic LX
Take some bolts off and put some bolts back in.
O Yea, theres a few wires too
Prelude, Integra DB9
I'm confused.
You say you want to swap a fuel injection head onto the engine,
but also want to use bike carbs? Why, then, use that head?
Also, I thought the injected 1.5 engines from around 1985 weren't CVCC. After all, once they had PGM-FI, Honda didn't need the pre-chamber.
85-87 civics either had carbs for the base models, or fuel injection for the SI models.
It literally was just ignition and fuel injection changes, and you got 10-20hp either way.
I prefer the hydra swap on 3rd gen civics. old integra dual cam 1.6 head, little work, and you have a 140+ crank horse setup that rips really good, IF you can find all the good parts still.
So you could get fuel injection as well as the extra pre-chamber mix? I didn't know that. No wonder Formula 1 cars introduced it 3 or 4 years ago.
I dunno if the 85-87 civics were all cvcc.
But you do not have any prechamber stuff with the hydra swap.
It was basically creating a 1.5 liter higher compression version of the dohc d16 found in the 86-89 integras (for US market at least)
same concept as the z6 and y8 heads on non-vtec obd0/1/2 blocks. since the non-vtec motors generally made compression with the pistons and the vtec heads (D series) usually made compression with the head chamber, combining each makes for a great peppy daily driver
1 - 10 of 10 Posts
