1 - 10 of 10 Posts
AUSDM EG8 Sedan
hey guys
im in the process of prepping a D16y1 Head (same as D16z6) to put onto my D15b7
i have dissasembled everything and got the head down to just the valve guides
im also going to take it into the machine shop for a clean, skim and check for any possible problems
i have a few questions...
1. my garage is fully enclosed - but the valve guides and a few other bits have started to corode a little - will the machine shop be able to deal with this or will they have to be replaced?
2. i cant seem to get the valve stem seals off - will the machine shop do this for me?
3. lastly - im going to do some very light PnP work on the head - should i do this before or after i take it into the machine shop?
thanks for any constructive replies!!
:sweatdrop:
AUSDM EG8 Sedan
is there a way i can tell if the head is bent before starting PnP work?
Honda City
It's called a machinist's straight edge. See if you can rent one or buy one. Then keep it diagonally on the head surface in various positions and use a feeler gauge to check for warpage. The feeler gauge specs are given in the service manual.
hey guys
The machine shop can hot tank the head to thoroughly clean it.
Yes they can do this but you should be able to do it as well with a pair of pliers.
Do it before.
:sweatdrop:
AUSDM EG8 Sedan
the machine shop said they were going to sandblast it - not hot tank
i have called a couple of machine shops now and they all say the same thing
is this ok?
same
soda for sure. and find out about a hot tank cuz that will get into the tight places that soda can't go.
AUSDM EG8 Sedan
one thing i do need to know is ...
i currently have a Bisimoto Adjustable Cam Gear on my D15b7 with D16a6 Cam
will i be able to use the same Cam Gear on the D16y1/z6 setup? or will i have to replace it?
1 - 10 of 10 Posts
