1 - 7 of 7 Posts
G
Head + Pistons = Compression
Z6 Z6------------9.2
Z6 Y8------------9.27
Z6 A6------------9.7
Z6 ZC------------11.58
Z6 86-87 A1------11.27
Z6 88-89 A1------11.58
This is something I have found and have been going by. However, the link on this site (somewhere) says that the zc pistons will give you like a 14:l compression ration???
Is something off here or am I just missing something???????
G
I have these numbers plus I have seen two other 'calculators' and they all give deifferent numbers with a WIDE range.
There was some discussion going on in a thread in the classifieds section but that was not the place for it.
I would really like to get some solid information on this. Some figures I have found differ by 3:1 compression which is CRAZY!!!!!!!!
G
Discussion Starter · #5 ·
P29 pistons in an otherwise stock D16Z6 engine even with the stock Z6 metal headgasket doesn't net 14:1 CR, it only nets 12.0 CR.
Trust me.
Here's the compression calculator:
http://www.c-speedracing.com/howto/compcalc/compcalc.php
And here's the numbers you punch in:
Bore - 75
Stroke - 90mm
Combustion chamber volume - 34.6
Piston dome - +7.2
Head gasket thickness - .037
Piston-to-deck height - .040 <------------------- thats what throws everything off.
CR comes to 12.03 with a displacement of 1590cc
I bolded the piston-to-deck clearance because too many people use the wrong number here. You need to use the number for the *PISTON* going into the block, not the block itself.
Had I punched in the piston-to-deck number for the D16Z6 I would have gotten a way incorrect 13.6:1.
There have been many pump gas D16Z6 engines built with P29 slugs, so that alone should tell you that the 14:1 number is wrong.
The only thing to watch out for with the P29 pistons with a VTEC head are the valve reliefs. they do not latch up the same, but they do clear unless you go crazy with the mill or have some crazy-ass cam with a shitload more lift than stock.
I'd go with the least amount of mill on the head and not deck the block to ensure good piston-valve clearance.
If you need the D numbers here they are:
http://www.muller.net/sonny/crx/pistons/crchart.gif
12:1 is 100% totally streetable on 93 octane fuel. Hell I've got a few friends running 12.5:1 on pump gas too. These are B VTEC builds making over 200whp on pump gas that ar also daily driven with zero problems.
So my point is that I think you should run at least the flat top 86-87 pistons or even better, the P29s fropm the 88-89 Integra.
I fell victim to the misleading info before someone correceted me. A very knowledgable person on honda-tech.
zc pistions (p29, pm7) would bump the compresison in a z6 almost to 14:1 depending on the headgasket. If you use the 2 layer y8 headgasket its 14.1:1. I am building an all motor z6 with a6 pistons and it runs close to 11:1 at 10.7:1 compression which is pretty deceont for a street car. Im aware that you arent supposed to run anything over 11:1 on pump gas, so i would try to get as close to tthat mark as possible here is a link
http://www.knology.net/~jediklc/D.htm
dx pistons arent a bad choice either...
two calculators with different results. PLus these differ with the data I have as well.
Something...
Somewhere...
is not correct.
G
Discussion Starter · #7 ·
Cool. Thanks.
Can you varify or dismiss the following info also AND give you give me some facts as to why like in the above? That way I can go to where I got my info and try to correct them also.
Thanks
Never mind the site is down. I will have to post it up later.
1 - 7 of 7 Posts
