I took the head off of my D15b VTEC and was wondering if I should put some oil in the cylinders to stop rust.
yep a thin coat just put it on with your hand
edit: im guessing your pistons are out as well? if the blocks gonna sit with the oil pan and pistons still connected you can just seal the top up air tight
I have a towel over it now. If I do this will I need to oil it?
i would still, how long are u letting it sit? im out at the farthest point on the east coast and i know if i dont treat any metal itll start to rust in days:(
Probably a a week or two. So just a thin coat around the cylinder walls and on the piston right? I'm getting the valves checked to see if they are bent and gonna be waiting on a headgasket and some head studs.
yes that should be it, best wishes with it all!
Thanks for the help.
