1 - 14 of 14 Posts
O
im going to buy a cometic headgasket wondering what size i should use on 15lbs
W
look down and search this was covered like a day ago. HD one is good.
W
yea thinner compression increase, larger lower compression but if you are all motor and want to be safer with thick hg and don't wanna lose compression then mill your head.---don't kno why im talkin about all motor in turbo thread but turbo people do it as well so w/e
W
yea SC setup same as how i explained the turbo setup
W
over here its 10 buck a mm. example 30mm 30 bucks
Stock will be fine, but wrather than buyinga $100+ gasket kit i would wrather get a commetic headgasket and hondata type intake gasket and piece the rest of the seals together you need. It would suck if you blew a gasket if you tune wasnt good and you coulda spent 40 bucks more for the high performance one like commetic that they use on ferraries or something with the coating for extreme sealing conditions.
C
extreme sealing conditions. hehe
it doesnt matter what head gasket you use, if you dont have arp head studs and its not setup properly you will blow it.
i am guilty of using a felpro permatorque headgasket for 15k miles at 18-20 psi.
i love em. if u have arp headstuds, you can use any hg you want except for the composite pieces of shit of course
1 - 14 of 14 Posts
