1 - 6 of 6 Posts
i have a z6 block and a head stamped P08-1 which is d15b right? but i know the z6 and d15b head are the same the only difference is the cam my cam is stamped D624 can anyone tell me if i have a D15B cam or Z6 Cam??????
Well?
they are the same cams, BUT you do have the "bigger" cam of the production run or so its said
A lot
I know nothing about cam codes, but just because your head has P08-1 on it does not mean it was removed from a D15B and installed on your Z6 block.
It is likely the head that came with it from the factory.
yeah the only head stamped P08-1 is the d15b but im not worried about that anyways because the heads are the same but cams are diff. the d15b cam is more aggressive than the z6, thats why im just wondering what cam it is d15b or z6
A lot
I have a D15B and my head is also stamped P08-3, which is why I made the above statement. I have no idea what the stamp on my cam is, Ive never bothered/needed to look.
1 - 6 of 6 Posts
