1 - 15 of 15 Posts
1989 Civic Hatch Zc
So I was torquing down my held bolts, 2nd pass around @53 lbs. Around 50lbs I hear a snap, I thought I broke the bolt, I pulled the bolt out and it was still in one piece, I tried to tighten it, and it keep spinning. How do I fix this problem?? Z6 head Zc block.
They call me Awesome!
Personally I'd take it to a machine shop and let them helicoil it but if you're tight on the budget I don't see a reason why Time serts wouldn't be a viable option as long as you've got the right tools.
dont helicoil it, it wont hold up if your gonna boost the car. Take the block to a machine shop, they have to have a timecert kit, and they WILL replace those threads for really CHEAP. I Had that same problem, but my dad had experience with machining, he drilled 2 bigger holes in the block and 2 bigger holes on the head and i bought the individual ARP head studs that they sell. It works like a charm.
93 Legend L Coupe.
:confused:
So use the wrong tools to do it?
:razz:
Yes!
I meant without. LOL!
Proper tools: Mill or a the VERY least a good, large drill press with very little runout on the spindle an chuck.
1989 Civic Hatch Zc
Thank you everyone for your input.. I decided to just drop the whole engine and take it to the machine shop.. they are going to time sert it. On a different note... Z6 head on Zc block, good combo?
Non-VTEC or VTEC ZC?
A non-VTEC block would be a 1.5 mini-me and a VTEC ZC block is a Z6 block...
1 - 15 of 15 Posts
