1 - 16 of 16 Posts
valve cover Bolt broke... help please
i broke the top rigth valve cover bolt (closes 2 the cam gear) because i put 2 much preasure. How can i get it out plz?
there is a tool/drill bit, called an easy out. you should be able to find them at any local hardware store. What you do is drill a hole in the stud and then screw the easy out in and turn it out.
www.rifftrax.com
1996 Civic Ex Sedan
Google 2 things "Grammer" and "closest honda/acura dealer
lol it's spelled "grammar"
op: an easy out is what you want.
\/ apply baby lotion here \/
'98 Civic 4 Door
thankz i now i know were to find the bolt now how can i get it out???
Drill the Broken Bolt right in the Middle with a Small Drill Bit, then with that Easy Out, it'll come right out :td:
Oh, and make sure when you put the New One, you put it tight so it can Break again!
1 - 16 of 16 Posts
