1 - 20 of 26 Posts
Like the top says has anybody ran 10psi on stock pump my friend wants to do this but I tell him not to even I am runing a walbro 255 on 8psi just to be on the safe side.
racist-bigot-sexist-homophob
Yes people do it all the time.
I'm running the stock pump on my setup w/ DSM 450's and it seems ok at this point ~14psi. I want to upgrade it but at least for the short term the pump should handle it fine.
i've remember reading somewhere that the stock pumps can support up to 300 whp on 450-550 ish injectors. have never try'd it though. just stick in the upgraded one and be done with it....
stock pump, 8psi on a 13T, 450s for 2years daily driven. no problems
-Luke
Lifetime Awesome Member
He can run the stock pump, but I would just spend the extra $100 or so and get a walbro to be on the safe side...
well either way, the stock pump can handle 10psi no problem.
you say ONLY $100, but have you changed the pump on a CRX? its not an "easy" job considering you have to drop the tank. depending on his chassis, it may not be worth the extra effort when the stocker will suffice
The Master Fabricator
Just remember that you need larger injectors and a means to control them (tuning) if you stay with the stock pump.
DO NOT USE A STOCK PUMP WITH A RISING RATE FMU AT 10 PSI...
stock pumps are good for close to 300hp, but would i trust one at that level? no
ive ran my stock pump up to 15psi on my t3 without issues though
X2 i ran stock pump up to 14 16psi spike on my z1 block...
i wouldnt trust it for more then 200whp tho
255lph pumps are ONLY 75bux SHIPPED for xenocron.
stock sohc at 10psi is no problem with a stock pump, when you push more then 250whp or anything build consider a 255
Only reason I only change pumps is because my pump is almost as old as I am.One less thing to worry about.
I did have my stocker up to 12 psi for awhile,normally 8 psi daily
1 - 20 of 26 Posts
