I just installed it, it's brand new.It appears my newly installed halfshaft/transmission seal is leaking. I'm guessing that's bad, what can I do about it?
then you installed it wrongI just installed it, it's brand new.
Love your new project ride. Could you be more specific? I'm pretty sure It won't go in backwards...then you installed it wrong
I ask this because i'm curious if there's not simply too much oil in the transmission. Are these seals simply dust covers? or are they actually intended to keep oil from leaking out from the seam between the halftshaft and transmission?Aight, after taking it all apart, moving the seal so it makes better contact with the halfshaft, it still leaks. Unfortunately I now realize that it doesn't need to contact the face of the halfshaft in order to form a proper seal just the shaft part, which implies that the seal is the wrong size, or has some defect along the interior ring.
Before I tear it apart again, can anyone tell me exactly how much oil is supposed to be in your transmission case? or where the oil level would be physically on the tranmission.
