1 - 6 of 6 Posts
a hatch
Doing a y8 build soon and i need the space up front. Im doing a EH Half rad so i can hopefully use my sinktrap. My question is will the hacking affect my car alot? I heard its just a notching,but will it affect the way its drives? Is it even worth going half rad? None of that "buy this $300 radiator" stuff please, i dont even have $300 in the motor so that is out of the question.
Any response is helpful.
Thanks
racist-bigot-sexist-homophob
edit: Whoa.....nm. I see you said cross member.
Do yo mean rad support? You should be able to hack away your rad support to get the rad to fit. I wouldn't hack away too much at the crossmember.
a hatch
I heard you had to do cross member and radiator support,the eg radiator is to tall. Not to sure.
Never touched the stock crossmember just hacked the ever living fuck out of the rad support.
dont cut your cross member... that keeps your wheels in place. if that fails you fail. hehe. into a wall.
like others said
u should be able to just cut the rad support a bit to make it work.
1 - 6 of 6 Posts
