1 - 4 of 4 Posts
C
Last night as i was driving my 93 hatch, and all of my guages went out on my guage cluster, (water temp, fuel, mph, tach...) The light was still on, but all guages stoped working also the turn signals dont work, but the hazards do. I hit a bump and they started working agian. Then after i got home, I had to leave to go somewhere and i started my car up and they didnt work. It sounds like a loose wire or something. I dont think it could be a fuse if it stoped working and came back on. Plus i dont really see a fuse for the guage cluster on my fuse panel, just a fuse for the light. All help will be greatly appriciated thanks!!
have you removed the cluster before? Like changing the bezel or something? You might have just gotten the connectors not on snug enough. worth the while to pull and reseat the connectors to the cluster.
If the gauges needles went to the high side of the gauge, you have a ground issue. If they went down, power issue.
There are grounds all over the dash area. A Helms would be ideal in this situation.
1 - 4 of 4 Posts
