1 - 9 of 9 Posts
For some reason every time i do a hard shift into 2nd i always end up grindin the hell out of it. all the rest of the gears go in fine on a hard shift. what could be the problem?
damn russianwonder, have I not preached enough why the SYNCRHOS are NOT at fault???
DAeDAe, need more info on your car/setup
d-series smartass
i had the same problem in my 93 dx. when i ran around like normal, no problem, but when i ran it above 5k and shifted, it would grind every time. it was predictable and consistent. any hard shift into second, SSSHHHHRRRKKK! but it ran fine, and shifted fine as long as i was easy on it.
D-Series Post Be-itch... gimme gimme gimme
motor mounts. the rear one, mainly. mine did that and I put NRgy motor mount inserts, and it hasn't grinded since.
I know..... lol. I saw one and had to have it. Also, I did the shift stabilizer, and there is a world of difference. I'd recommend that one, too.
im for sure its not the synchros it would grind every time. and a matter of fact i have a polyurthan (not sure if thats how you spell it) rear motor mount. ill try it c what happens!
1 - 9 of 9 Posts
