Hi, my name is Kai and i live in northern Germany.
I'm turning 40 soon and I'm clinging on to my youth by driving a del Sol
- here known as the 3rd gen CRX.
Well, driving is a bit far fetched.
I own two Sols, but none of them is in driving condition.
The yellow One is a '92 with a Z6 and the green One is a '96 with a Y8
The Z6 startet burning Oil at the begining of last Year.
If I drove it over 3000 rpm, let off the gas and put down the Pedal again over 2500 rpm, a huge black cloud came of the exhaust.
Since it's a common Problem with sticking Piston Rings on the D Series, I thought I could "unstick" it by driving in high revs.
So I took it on the Autobahn on regular bases - didn't help with the oil, but on Sunday July 3rd after a short drive with 200 kph (~120 mph) the rear right Tyre blew off at decelerating and so I crashed into the Guard Rail two times at circa 130 -140 kph (80-85 mph).
So I bought the cheapest del Sol I could find and now I'm trying to make one good car out of 2 bad ones.
The "new" One has a lot of Rust and a Front damage that is worse than it looked.
The seller said he bought it like that, drove it for a Year and let it sit for 6 Years.
I highly doubt that, because the Hood didn't close anymore - I thought it might just need some adjustment, but nope - the frame was so bent, that the Hood latch was about 3 cm or 1.25 Inch next to the lock.
Since both Cars are completly torn apart, I thought I can go all the Way.
I am a Mechanic and I run my own Workshop - so Labour is not the problem - maybe Time is.
There are some Questions running through my mind, but they are for other threads.
That's why i registered in this forum.
I bought the '92 in 2015 and here is what I've changed on it.
I leave out repairs and maintenance:
The Mods on the Green one which were not on the Yellow one:
Until I finish the Sol I'm stuck with driving a first gen Smart Car Diesel.
The only good things I can say about it is: The Interiour is more spacious than you would expect from such a small car and it gets a great gas mileage. I Usually drive it around 3.5L per 100km or 67 mpg.
But it's a nightmare to work on.
- D16y8 Intake manifoild with B16 Throttle
- Integra GSR Airbox
- XTD Flywheel and Stage 2 Clutch
- Header and Catback Exhaust made by TSS (German Brand)
- Header Wrapped
- 200 CPI Metal Core Cat
- 4th Gen Prelude Seats and Shift Knob
- B16 front Strut brace and reat Sway Bar added
- All suspension Bushings changed to PU
- Eibach lowering Springs 35mm (1.38")
- Mishimoto Radiator
- Iridium Spark Plugs
- Leather Cover on the Stock Steering Wheel (with no Airbag)
- Front Lip from the Civic EG6
- Rear Spoiler by MS Design
- Chipped ECU
- Slotted and drilled Rotors in front
- The Rims I had the Accident with were Borbet T 7x15 with 195/50 R15
- Koni Shocks
- Rims DBV Arizona 7.5x16 with 215/40 R16
